Jelen wrote:Thanks guys,, it will help. Anyway I will take shims, for sure. I will also go with Airglas fork, or heavy duty C206 fork.
If is it allowed? I hope so, it meets standards for tyres (type III, 4ply). I will consult with CAA, but if it needs to be allowed, I hope for only some minor change.
Next step will be Sportsman STOL.
The Airglas fork comes with an STC which permits the 8.50 x 6 tires. At least in this country, you must have a model specific approval for tires other than that which is on the type certificate, or approved by the manufacturer, NOT just a tso’d tire.
Installation on a certificated airplane requires in most cases, two “approvals”:
One is a tso, which simply says the part is approved for use on aircraft. That’s what you referenced as a “Type III, 4 ply tire”.
The second is a type specific approval, which may be on the TC, equipment list for part 23 aircraft, or approved via a Supplemental Type Certificate, or STC.
Cessna never approved the 8.50 x 6 tire on the 172. The only approval for that is the Airglas fork mod, as far as I know, which also approves larger main tires.
Before you get too carried away with buying stuff, talk to your maintenance technician, otherwise, you may have an ugly surprise when your annual inspection comes due.
