Hammer wrote:Some of the things you just wouldn't believe could be like that, given the condition of everything else. But sixty years of repairs and modifications from dozens of people leaves a lot of room for abnormality.
Every time I set out to do one little thing I found another five things that could be better, so I did those too. And I started out with a nice airplane...not a project plane by any means.
Good luck with the rebuild!
corefile wrote:Little update on the project - I've finalized the new engine purchase and sent in my deposits, this is what I have gone with:
Engine: Pponk - Now called Northpoint XP470 as Steve Knopp sold the STC , I'm having it built by Ly-Con in Visalia, Ca and I went with the option of doing 8.5:1 compression pistons and well as porting the cylinders.
Prop: MT 3 Blade prop - MTV-9-D I was able to find a good deal on this from someone doing the test work on the new Hartzell 3 blade
Engine Mount: Seaplanes West Engine Mount - Ok technically I didn't need this - my stock cessna mount is in great shape (for sale by the way) but after flying in a buddies plane I was shocked at how smooth it ran - when I asked he said upgrading to the Seaplanes west engine mount really smoothed it all out.
Seaplanes West Exhaust:- I probably could have gotten by with my old exhaust as well - was able to get this and the mount on the cyber monday deal. Saw the other post on seaplane west exhaust - got me thinking about this a bit - but after looking into it a bit more, its not an issue.
Ok now if I could just get someone to send me some $$ to pay for all of this I'll be good to go.
denalipilot wrote:I was somewhat in your position a few years ago (basically all-new everything, firewall forward on a 170B). In my case it made no sense to hang all that new stuff on a 60 year-old, beat up, ugly, drilled and patched firewall, so I sourced a new stainless steel firewall and have been glad I did ever since. Not sure if that's an option for you or not. Best of luck with the total project.
-DP
corefile wrote:denalipilot wrote:I was somewhat in your position a few years ago (basically all-new everything, firewall forward on a 170B). In my case it made no sense to hang all that new stuff on a 60 year-old, beat up, ugly, drilled and patched firewall, so I sourced a new stainless steel firewall and have been glad I did ever since. Not sure if that's an option for you or not. Best of luck with the total project.
-DP
Looks like I may be going down this route, I have a few smoked rivets around the cowling/firewall and one that the head popped off from some corrosion - so the right way to fix it is drill it out and address any corrosion - then prep the cowling for disimular metal touching (Aluminum & SS) and then it just seems silly not to replace the old patched up firewall at that point.
Where did you get your SS firewall?
asa wrote:So you already had a stainless firewall?
marcusofcotton wrote:With all you're doing on your forever plane, seems like an upgrade to titanium for the firewall may be in order.
and don’t forget the tail spring either!Hammer wrote:marcusofcotton wrote:With all you're doing on your forever plane, seems like an upgrade to titanium for the firewall may be in order.
Don't forget the titanium gear legs and axels!
