Hi,
Not wanting to hijack the G5 thread, and given the proximity to certification of the AV-30, I thought this would be a ripening topic for discussion.
I got here in a roundabout way. Have an inop enroute Garmin155 TSO in my panel. My Nav and the Garmin could be selected to drive my Century 2000 Autopilot. So, I thought to replace the 155 with the new Garmin 175. So far so good. Can the 175 drive my autopilot? Maybe for simple headings but apparently I need a GPSS steering module for the Century to fly approach elements like procedure turns using the Autopilot.
Have been talking to 3 avionics shops plus a helpful IA on the BeechTalk list.
The GPSS module for the Century is $3,567 + installation! Pretty pricey.
A suggestion has been made that for less $$$, I can install a G5 in HSI mode (replacing current vacuum driven HSI) and this will interface to the Garmin 175 and also provide GPSS steering to my autopilot.
It seems to me that the AVC can do the same thing, plus others. Thus, the interest.
I could also replace the AI with a G5 or AVC-30 and get rid of my vacuum system. Is my thinking on all this correct or merely wishful?
I don’t fly IFR that often and now I can only do ILS, Localizer and VOR approaches. Say I fly from California to the east coast. I checked a number of airports that I might fly to and they all had these types of approaches. So the 175 would add some RNAV possibilities. I have WAAS GPS as part of my Appareo ADSB In/out setup. My current equipment designation is /A as I have DME. Have been told that this will work for filing direct, say LA to Wichita. ATC asks if I am GPS enabled, I respond Yes, and usually says Ok.
Not clear to me what my equipment / designator would be if I installed only the G175?
Debating whether to just get the Garmin 175 now or wait till next year and get it along with two G5’s or AVC-30s? I am sure that I could work around any IFR challenges with current equipment even if I have to do a bunch of VORs in sequence for XC.
Any comments appreciated.
Best,
Tom
