I’m usually pretty comfortable with the dismantling phase of any project but for some reason I get squidgy every time I take even a screwdriver to my plane. I’ve done a couple projects, repairing a broken shroud under the rudder pedals and replacing a carb heat cable, but I’m uncharacteristically cautious and timid. Panel replacement is proving no different. My first thought was to remove the door and go home to replace the panel in my warm garage but it seems that would require removing the hinges from the fuselage and I don’t really want to disturb those heavily paint-encrusted screws. I decided to do the work in place.
Now I’m stuck trying to get the existing panel off. So, a few questions:
- How do I remove the door handle?
- I don’t see any screws holding the panel in place, is it self-clamped in place by edges that grip onto the door frame?
- There are a couple screws holding the armrest in place, are they screwed into the door frame or just the panel?
- If the arm rest is screwed into the door frame, what is the easiest way to measure where to drill corresponding holes in my new panel?
- How many screws should I use to hold the new panel in place? One in each corner doesn’t seem like enough but I’m not wild about drilling a bunch of holes in old Wanda if I don’t have to. Should I use some sort of sealant/caulk around the edges?
