I have the same switch you do. My IA added a lit rocker switch to turn on the Pulselight module. Basic operation is to turn on the landing/taxi pull switch all the way to turn on both lights to warm them up (I have HIDs, which take a few seconds to come to full brightness), turn on the Pulselight switch, then push in the landing/taxi switch, and both lights then pulse at full brightness.A1Skinner wrote:Did you add a seperate switch Cary? Or does your 172 have seperate landing/taxi switches already? My 180 has the old school pull knob. Pull out one notch for taxi, two notches for taxi and landing. I'm sure I'd have to put in new switches if i went the wigwag route.
Pilots Goodies wrote:Hi,
I know this is an old post, but I just want to share a new option for those of you that are willing to try something different.
A Par36 light that will fit as a direct replacement and it does produce over 2100 lumens.
for more information please visit:
http://www.goodiesforpilots.com
[url]www.goodiesforpilots.com/url]
Thanks
Yamil Quinones
88H wrote:To clarify:
Pilot Goodies is talking about a drop in replacement that has the wig-wag controller built in. The first time you turn on the lights you get the wig-wags. If you then turn it off and turn back on again, you have the solid light. So there is NO need for a separate controller.
I am going to install on my bird and I will give a report on if it works as advertised.
If so, seems like a no brainer for the price. L
asa wrote:88H wrote:To clarify:
Look into the current they draw (which directly relates to brightness). I think it's 0.9A versus a Whelen 1.2A, Rigid's 1.6A (23W) or 2.7A (40W). The wig-wag is nice, though, as well as the price.
Bagarre wrote:asa wrote:88H wrote:To clarify:
Current draw isn't as direct a measurement in LEDs as it is in incandescent bulbs. Lumens is a better comparison as that is how bright the light is. A more efficient LED will have a higher Lumen at the same current draw as a less efficient LED.
I wish the wig wag was the other way around where you have to cycle the switch twice to turn on wig wag.
That way normal functionality remains the same (turn on switch and you get normal lights)
88H wrote:1. I think they are closer to $70 or $80 each. Will let you know when they come in.
2. I am not sure which feature comes on first. Only used that as an example. For me it would probably be better to have wig-wag first because I switch on lights everytime I crank up. Will post that when I get them installed.
3. I have no idea about lumens and amps. Hadn't even thought about asking. Probably because I am currently running the old style incandescent and I guarantee these will be brighter with lower power drain than what I am running now. Will post that too if I can get it off the paperwork.
4. I have a pretty cranky mechanic so I am sure he will let me know if they are not certificated. Was going to pass along paperwork to him as soon as I get it. Will let you know about that too.
I will keep you posted. L
Cary wrote:Actually, mine don't wigwag--they pulse together, because wigwagging when they're as close together as when paired in the leading edge of a Cessna wing would make them appear to be on all the time, negating the benefit of the wigwagging. If I had them on the tips or 2 pairs, one in each wing, then wigwagging would work well.
Bagarre wrote:
Ask your mechanic to show you the PMA and TSO for your existing PAR36 bulbs - or your nav lights for that matter.
http://www.avweb.com/blogs/insider/AVWe ... 196-1.html
