Hi guys, I do apologize for my late reply.
Honestly, I'm not trying to start a discussion or give anyone hard time, this is just my personal opinion.
Let's get the real fact.
First, as someone say on the forum in a previous post, the original light bulb was the GE 4509 or whatever was the original part number that has being superseded whatever amount of times directly from Cessna.
Now you can have replacement bulb made by a different manufacturer not only General Electric and none of them will have STC or PMA documentation, just the 4509 part number.
The following is an example:
http://www.aircraftspruce.com/catalog/elpages/landlights3.php?clickkey=5663Or
http://www.aircraftspruce.com/catalog/elpages/martek4509.phpand finally and it says FAA approved but is not a General Electric
http://www.univair.com/electrical-lighting/view-all/4509-sealed-beam-landing-light-bulb/It's just a light bulb replaced with either same technology or a better one like in the Whelen Quartz 4509. Still a incandescent light but the filament is quartz.
On the LED light, I guess the FAA will argue or use as a reference or on their defense that is different technology LED (Light Emitting Diode) compare to the original (incandescent).
You'll find FAA inspectors that will do a field approval for this kind of variations, some other will say nothing and others won't even tell you their personal opinion because they rather won't even deal with this kind of discrepancies.
For more information visit my website:
http://goodiesforpilots.com/picture-par-36 to read the words from a renowned aviation editor.
Any way, the way I see this is the same with the current incandescent light bulb and the multiples manufacturers of a single item the Par-36 light bulb. It's all matter of time. I'm sure that at some point there is going to be many options out there that The FAA will have to finally make a final interpretation about this topic.
Remember those times of "No electronic devices allowed onboard aircraft" ? Now you can find them even inside the cockpit...
What about the tire tube brand inside your tire, what about an old Piper Cherokees, some of them do call for a Chrysler 50 amp Alternator are they approved, STC? PMA? and so on in many other consumable.
On a brief description about the lights on goodiesforpilots.com I, personally just got tired and frustrated of replacing incandescent lights on my Cessna 182 in a 3 year period. That's when I decide to do something. The result is the only 18LED Par36 on the market capable of over 2100 lumens (at least that I know) yes that is right. Over 2100 lumens and there is a video on my website to prove that. No tricks.
Also I want to clarify to someone that say the load is directly related to how bright the light is. Excuse me if I say something wrong and please correct me if anyone find me using the wrong term on the following statement. Unfortunately, the consumption in amps is not related to the intensity of the projected visible light. The reason is that there is always a LED Driver or at least that's how they called. Because all LED are low power consumption. The 12-14v or 24-28v on our electric system has to step down in order to make the LED work. If you connect directly those 12 or 24v to any LED it will burn them right away.
Because of that, the consumption (load) is equal to the components quality of the LED driver and is not related to the intensity or brightness from the light.
Example,; that LED Christmas light. Have you notice how bright they are? But they consume 1/5 or less than the old type of Christmas lights.
At least you don't need an STC to use Christmas Light on your Christmas decoration around your house.
And last
I do have to disclose the Non-Certify Version because liability reason. I want to be clear and not fall under a false advertising charge by consumers or omitting/ unproven information also part of false advertising.
Have you ever try to buy something for your aircraft and as soon as you disclose it is intended to be used on an aircraft they just won't sell it to you?
What about carburetors that are used on many experimental aircraft engines (Example Rotax) but they have to disclose "Not for aircraft used"
Yes, I'm currently waiting for the Flashing Landing lights. They incorporate a circuitry that allows you to cycle the power and make them steady or flashing. They are running late on the production so I'm expecting them by April.
Anyway the current lights still available. Take a close look to one customer Wing Tip incandescent lights and the cowling lights on a Cessna 182RG and let's compared apple to apple.
http://goodiesforpilots.com/picture-par-36Let me know if you have any question
Thanks
