Backcountry Pilot • My new Skywagon! Let the mods begin!
179 posts • Page 6 of 9 • 1 ... 3, 4, 5, 6, 7, 8, 9
Re: My new Skywagon! Let the mods begin!
bat443 wrote:.... I installed the BAS handles in a 170B, used screws so that I could take the handle out if extensive work was ever need on the aft bulkhead.
Rivets look much better than screws IMHO, but this makes a lot of sense.
StuBob wrote:A tip on the handles: I have orange safety tape wrapping the ends of mine, which has kept me from bumping into them with my....um....upper thighs.
My tip is to just stow them when they're not actually in use.
Your huevos, errr upper thighs will be safe that way.
Just to confuse things, on my 180 project I plan to use rivets as I have the aft tail cone access panels sold by Tony at Aeropod if I need access. I think rivets look more professional than screws. Not quite as tight in the tail cone of a 180/185 as a 170 if you need to do something.
bat443 offline
It's amazing how I'm finding stuff I miss that I had put in my previous 185. For instance, Precise Airflow Vents and Rosen Sun Visors. Two more mods I need to install. Ordered.
Barnstormer offline
Those Precise flow vents are worth EVERY penny!
I'm so pleased. Gone are the Monarch Caps & Plates. Replaced with the type of caps and plates Cessna originally installed. Yes!
Barnstormer offline
And two more mods. Precise Airflow Vents and Rosen Visors. Both purchased from Sporty's Pilot Shop. The drill bit and grind stones are if you need to put the thermometer through the windshield.
Barnstormer offline
Looks great. No problems fitting with the V-brace in-place?
wagonflyer offline
wagonflyer wrote:Looks great. No problems fitting with the V-brace in-place?
Nope, clears fine.
Barnstormer offline
What about that thermometer in the windshield thing? Sounds scary.
StuBob offline
Aircraft: Cessna 185 Skywagon
Barnstormer wrote:
DeltaRomeo wrote:Why don't you just install numerous USB charging ports instead? You know thats what it going to be used for...
That's an excellent question. And the answer is because Garmin hasn't yet learned what a USB connection is. Both my powered inRreach mount and my GDL 39 cables have old-school cigarette lighter plugs. Hopefully some day they'll figure it out, but probably not till everyone else is charging things through the air. ;-)
Another good reason is the 'standard' USB plug is slowly becoming obsolete in the electronics industry, there is a move toward the smaller 'USB C' connector.
I personally like to keep the power plug (aka cigarette lighter) because I can always find a charger that adapts to whatever the 'latest' plug that my gadgets have. Once/if the USB plug becomes obsolete you would have a useless plug in your airplane.
jrollf offline
I have installed three sets of these vents now in customer wagons. I have yet to have one clear the V brace. I end up cutting the sleeve down leaving about 1/8" to the 1st O ring. This lets you slip it up and in, but still a snug fit. This was with both an Atlee and orig Cessna V brace.
Glad you had it easy Phil. LOL
Bigrenna wrote:...Glad you had it easy Phil. LOL
Me too! Interference free on my previous '73 185 as well.
Barnstormer offline
LEMOS are in. Man I love these.
And 24v charging adapters. Can't live without these. Keeps everything fully charged all the time. Two more on the Co-pilot side. Ignore the label, I need to "adjust" those.
Barnstormer offline
Apparently Maule is not the only manufacturer that identifies the "Mic" location with "Mike" :D
DeltaRomeo offline
Aircraft: M5 180C
DeltaRomeo wrote:Apparently Maule is not the only manufacturer that identifies the "Mic" location with "Mike" :D
Nice, I hadn’t even caught that. Too funny.
Barnstormer offline
Looks like you might get more than you bargained for if you hit that primer...
Prosaria offline
Lad, if you want to get a pint and talk with mic that is fine. But some just want to plug in a mike and talk to the tower. Sure enough, as I have hung from my heels to kiss the blarney stone, I can understand why it is the way, it is.
DENNY
DENNY offline
DENNY
So, uh, what’s new??? Updates man updates! Lol...
Flying Dave offline
Aircraft: Aviat Husky
No new mods to report. In Montana with her now, she flew great. Mods to come after I’m back in Alaska:
Removing the flap gap seals
Sportsmans STOL
Installing the Reiff engine heater
Folding rear seats
Super extended baggage
Pockets pockets everywhere
Barnstormer offline
