robw56 wrote:Late model 180's (not sure which year it started) have the big tail like a 185.
I think they were called the Skywagon II. I ogled a nice one a few years back at Crane Lake.
A1Skinner wrote:
I think anything '64 or newer, with a factory float kit had the bigger dorsal. Also had 3 side windows.
Slantbuggy wrote:the dorsal is only for certain floats, its how they got them approved for that particular airframe. Most 180/185 dont use a dorsal, however some like the amphib aerocets do require a dorsal on a 185
Halestorm wrote:Slantbuggy wrote:the dorsal is only for certain floats, its how they got them approved for that particular airframe. Most 180/185 dont use a dorsal, however some like the amphib aerocets do require a dorsal on a 185
You mean the ventral fin? Wipline and aerocet floats require a small ventral fin on the belly while EDO floats do not.
Dorsal fin in the 180/185 is the small fillet section at the front of the vertical stabilizer.
For many years one could buy the sheet metal bits from Cessna to convert the small dorsal to the larger style, this was much cheaper than trying to source a larger stab for the higher gross weight.
propeller26 wrote:That sure looks like the P2V at the strip in Middletown. Often wondered it's story.
