Sky.Junkie wrote:Any other wing folders other than the Kitfox?
What are the chances of finding a Kitfox with a 912i? Or maybe finding one with a bum motor and having a 912i installed?
Also, I really like the Aerotrek A220 but it looks like it is just a EuroFox / Kitfox. Does anyone know the difference between them?
buck_justice wrote:Luscombe, C-140, Chief, taylorcraft all with tested tryed and true engines. Flying safely for decades with billions of hours. The folding wing thing is a farse. Your plane needs to be at the airport ready to go. When you get an extra hour, you go fly. Its hard enough to find time to fly without dragging it to the airport and assembling it. One hour a week is only 52 hours a year. Thats barely enough to keep a pilot proficient. Parts are available from AC Spruce, wag, and several other sources. They hold their value if you don't tear it up and even if you do you can get the bulk of your money out of the parts. My two cents
EZFlap wrote: The Zenair 701/750 might be a good choice for a few reasons. ......The airplanes are able to be used on wheels, skiis, floats with minimal modifications, and Zenair offers a float kit designed for them
If and when you do get to the "extreme" end of the STOL operations spectrum, you can convert them to tailwheel configuration and great big bush tires.
If you are on a tight budget you can scratch build and save money at the expense of time
If you have a reasonable amount of money you can buy a 400 hour quick build kit............
hotrod150 wrote: I have seen quite a few Z701's, live & in photos, and have never seen one configured with tailwheel gear.
8GCBC wrote:DO NOT give yourself a timeframe for purchasing an aircraft with your limited experience!
SAME as I suggest to others hoping to ocean sail ...crew for at least two years and watch others spend money at an alarming rate. Then decide which boat is best.
Keep your head in the search but, keep it an open end project. You may find an excellent value tomorrow but, you may not either.
hotrod150 wrote:
I have seen quite a few Z701's, live & in photos, and have never seen one configured with tailwheel gear. Ditto the Savannah which seems to be a Z701 knock-off with a few small changes (VG's instead of slats, etc). I have heard of the Pegazair which is apparently a modification of the Z701 design on tailwheel gear, but I have seen exactly one Pegazair photo and it appeared to be ginned up using photoshop and not a photograph of an actual completed airplane.
As far as building an airplane...I see that suggested pretty often when someone asks about what airplane they should get. Building an airplane, even a "400 hour quick build kit", is a huge undertaking and IMHO is much more daunting than learning to fly or buying your first airplane. For the average guy / first time builder with the usual job- & family-related demands on his time, even a 400-hour kit is gonna take at least a year and there is a pretty good chance it will never get finished. I would always recommend that someone's first airplane be bought ready-to-fly.
There's plenty of nice airplanes out there meeting the OP's parameters. Just a matter of flying enough of them to make an intelligent decision.
Users browsing this forum: No registered users and 17 guests
