Also posted this at CPA.
I know there are many 182 owners in this forums and some owns the MT prop.
Starter now moves the MT prop quick , this morning I was starting the engine and didnt start got a kickback and broke the starter adaptor.
Maybe the MT prop is too light and the starter adaptor goes too fast and jumps ? Or a small magneto miss timing?
Seems to be this happens a lot with Continental's , the kickback happens much easier with the MT prop because of its lightweight.
with not enough mass to carry the piston thru top center and if impulse causes the mag to fire before piston has passed thru top center it can cause a kick back
Engine is a TCM reman with 450 hrs
Trying to know what causes this and try to avoid it become a recurrent issue.
From what I have read so far .Seems to be, the faster the cranking speed the less the lag angle should be.
With the MT prop the motor goes faster than before
A solution is timing has to be set at less degrees than it is.
How much power will I loose retarding the timing a couple of degrees?
Any other ideas are welcomed.
I have also been recommended changing to another type of magnetos or to the old style starter adaptor and starter.
Honestly there should be a solution not involving more changes and changes.
So far Im inclined with the timing retarding theory.
By the way Im loving the MT prop , but not so much the Continental starter adaptor.
