Battson wrote:GB wrote:https://www.youtube.com/watch?v=-FLjPoxsk7Y Not your Cessna's spring gear.
Yes that was described in an earlier video too. From a shock absorption perspective it looks like it could perform better than pure spring gear, but I bet you could rock a pint-sized Cessna like that too, if that's the yardstick.
Yes you can rock a Cessna, you can rock any GA aircraft if you have a dude on each wingtip, but that was not the point (or yardstick) of what they are showing in that video. If you were to do that in a Cessna it would keep rocking back and forth a bit after you let go from rocking the wings. Its what’s causes the Cessna to waddle or rock side to side when going over big holes and rocks. It’s the nature of a sprung gear, it’s “simple physics”. The downward force creates energy, that energy is returned as upward force and there is nothing to absorb that return energy so you get the Cessna bounce, or waddle, you are transferring some of that energy back and forth between the left and right gear. What they are showing in that video is that when there is a downward force on the gear, the resulting upward force, or energy if you will, is absorbed by the shocks. So you don’t get the bounce of a true Cessna style sprung gear, or the waddle you get from going over rough terrain. A pint sized Cessna would 1) probably had the opposite tire come off the ground as the gear has no pivot point, and would act more as a lever 2) have keep rocking back and forth after they let go, where as the rv-15 did not, it pretty much came back to straight and level with no rocking motion, Much like how the oleo gear absorbs that return energy. The jury is out on how durable this new design will be, from the pictures the gear box looks substantial, but good on Vans for pushing the envelope.
I’m looking forward to seeing how it performs and the durability, not in comparison to a tricked out supercub or a Just Aircraft with a gear leg that attaches to the midpoint of the door frame.. but to a Cessna 140/170, Luscombe,Murphy Rebel, Glastar sportsman, etc, and even current Vans owners that want to get in on the backcountry wave. A very capable backcountry plane, but still fast. When you have a headwind, and you look down at the road below, cars are not going faster then you. All while burning less then 10gph. With the industry leader in kit planes backing it, top notch support, top notch builder manuals, latest kit technology to make assembly easier and faster with the fit and finish as good as many certified aircraft, all metal skin, a built in network of 3rd party companies building mods, and a kit with pretty affordable prices. I think there is a market there, and they will dominate that market.
