Nark wrote:Very "experienced" pilots can ground loop anything when they let skill/judgement lapse.
Mastering any aircraft on long grass runways before heading to the backcountry is how you prevent ground loops.
Sorry I didn't give you a specific airframe. There isn't one.
BluNosDav wrote:I know that ALL tail-wheel aircraft CAN ground-loop. But, not all aircraft are created equal, so, some models must be less likely to ground-loop than others. If a pilot with little or no tail wheel experience wanted to get some instruction and then possibly purchase a tail-dragger for back-country use, which makes & models should he consider, and which ones should he shy away from until he gains more experience & training?
BluNosDav wrote:Thanx Guys, for all of your replies! And please keep them coming, if anyone has more to add . . . . .
I did not intend to malign any particular makes & models, but, some trends cannot be ignored unless you have very deep pockets. Given a large enough sample of different planes & different pilots, insurance companies make up their rate tables. But, before calling Avemco and asking them about every tail-wheel airplane that is available on Trade-a-Plane, I hoped to get some general guidance from the experienced operators here on BCP.
Up here in AK, the most popular airplanes for the back-country are: many many PA-18's, occasionally a rebuilt PA-12 or PA-20/22, plus a lot of C-170/180/185's, some 7/8GCBC's, and a selection of other lesser known types. And although there are also a bunch of big tires bolted onto C-172/182/206's, it is the tail-draggers that seem to dominate the marketplace.
So far, it sounds like Citabrias and Cubs have the most recommendations.
mtv wrote:If you're really worried about ground loops, buy a tricycle gear airplane.
