1955 Cessna 170B rebuild
Sounds like there is a hot wire on one side of the master relay which goes to the starter switch which is cable actuated.
You're shunt will measure amperage in line with whatever circuit it's placed in. If you put it in line with starter cable which only goes to ground while the starter is engaged then you'll be measuring the amps being drawn by the starter. If you put it in line with the wire going from the master relay to the buss then you'll be measuring current drawn out of the battery by system loads.
Halestorm offline
956
- Aircraft: C-182E Pponk
Man, if you're going this deep, can you convert to a more modern starter motor/solenoid/switch? I never liked the pull starter.
2854
A1Skinner wrote:Right, pull starter. I was thinking a keyed starter with a starter selenoid. I would consider doing it to the battery, that way if you ever switch to keyed starter you don't have to change the ammeter wiring as well. Or just do it the way the IPC states, can't go wrong that way.
That is a good point as well. I hate options
kygreen229 offline
130
Zzz wrote:Man, if you're going this deep, can you convert to a more modern starter motor/solenoid/switch? I never liked the pull starter.
There is a new starter that saves some weight made by B & C products that allows you to put in a key and a push button switch. Small price tag of around $620 i believe it was. Maybe some day, right now just want to get it up and going and put that money towards fuel.
kygreen229 offline
130
My old 170 had the C145 èngine with the pull starter & it worked just fine.
You did have to make sure it was adjusted properly with regards to the linkage fully engaging the pinon gear before the starter motor was energized, but that wasnt hard to do- just follow directions.
10534
81D had an O-300D with a starter solenoid on the key and I always thought better of it.
When I got 95D, she still had the C-145 pull start and I REALLY liked it after the first start. It's just a cooler way to start a motor and made me feel more connected to the plane. Odd, weird, crazy but I like the pull start better.
Bagarre offline
794
- Aircraft: 1952 Cessna 170B project
Front window sealed.
kygreen229 offline
130
A wiring in except the engine monitor at this point, radios light up, beacon turns on, turn coordinator spins up. Kinda startin to sound like an airplane.
kygreen229 offline
130
Kinda starting to look like an airplane, too. After shadowing your trek from ground pounding to private pilotdom, I'm looking forward to your finished product (probably not nearly as much as you are, though, right?).
3801
3263
- Aircraft: 1957 C-180A
Thanks guys, its been a hell of a learning experience and still so many ways to do things differently. Paint is in the near future without a doubt. Just want it to be safe, clean bird that I can build time in and continue to learn in. Just completed my single engine commercial checkride two weeks ago. Ready to build that time!
kygreen229 offline
130
kygreen229 offline
130
Selkirk foam going in
kygreen229 offline
130
Looks great! I know how much work that is!
robw56 on Fri Jan 13, 2017 5:35 pm, edited 1 time in total.
3263
What did you use to seal the windshield? After a rain storm dumped on my 180 while it was parked outside a couple weeks ago I found out it leaks like a sieve!
3263
That looks great. It appears that you didn't paint the floor (maybe an illusion?). If so, what was your reasoning there?
1532
robw56 wrote:What did you use to seal the windshield? After a rain storm dumped on my 180 while it was parked outside a couple weeks ago I found out it leaks like a sieve!
I used the felt and strip caulk. Then used an aircraft RTV sealant for the final outside seal.
kygreen229 offline
130
asadarnell wrote:That looks great. It appears that you didn't paint the floor (maybe an illusion?). If so, what was your reasoning there?
I did not paint the whole interior like most have done previously. The floor will be covered with carpet or Aerodot flooring. Hoping to spring for the Aerodot however I already have carpet. It just simply comes down to money and time.
kygreen229 offline
130
The carpet acts like a filter catching all the sand and grit. You can then pull the carpet and clean it, and hopefully not have most of the junk not in the recesses of the plane.
mghallen offline
50
- Aircraft: C180
PA18
mghallen wrote:The carpet acts like a filter catching all the sand and grit. You can then pull the carpet and clean it, and hopefully not have most of the junk not in the recesses of the plane.
also a valid point!
kygreen229 offline
130
