You gonna keep it at full length?
As I recall, you were talking a while back about cutting it down to 82 or less.
Longer is better IMHO unless you have tip speed issues.
What's the engine redline?
hotrod180 wrote:You gonna keep it at full length?
whee wrote:hotrod180 wrote:You gonna keep it at full length?
Your recollection is incorrect![]()
It will likely get cut down to 86" maybe 84". Or maybe it will get left full length. Once we determine what rpm we are currently achieving we will determine the path forward.
2600 or 2800 rpm is the redline depending on engine model.
Bagarre wrote:
Any worries about harmonics and possible damage to the crank if you use a non-standard length?
whee wrote:….now that Catto will soon be selling blades that will fit a McCauley hub.
hotrod180 wrote:whee wrote:….now that Catto will soon be selling blades that will fit a McCauley hub.
First I've heard of that-- got a link for more info?
Bagarre wrote:whee wrote:hotrod180 wrote:You gonna keep it at full length?
Battson wrote:whee wrote:….now that Catto will soon be selling blades that will fit a McCauley hub.
I think Whirlwind (no, the other one) have been doing that for about seven years now? 2100mm blade disc.
whee wrote:hotrod180 wrote:whee wrote:….now that Catto will soon be selling blades that will fit a McCauley hub.
No. They have a Facebook page and an email list which they are using to share the info.
Bagarre wrote:
An Aeromatic Prop has wood blades. You should put one of those on just to troll people
whee wrote:.....I always wanted an Aeromatic to put on my Luscombe.
Yes, there is some concern about harmonics. Both 84” and 86” have been field approved on some aircraft with this engine but the numbers are small. However, I had custom forged pistons designed and manufactured so harmonics are mostly unknown at this point regardless of prop length. What I really need is a wood core prop which may happen now that Catto will soon be selling blades that will fit a McCauley hub.
hotrod180 wrote:whee wrote:.....I always wanted an Aeromatic to put on my Luscombe.
A guy I know has an Aeromatic on his Ranger-powered Fairchild 24.
It works great.....here at sea level.
He just told me the other day that he flew it down to Reno for the air races,
and it didn't work worth a damn at that elevation--
it kept wanting to go into high pitch on takeoff roll.
So for anyone who's gonna be operating at different elevations,
I don't think they're a good choice.
Bagarre wrote:...The manual tells you that field elevation changes of a few thousand feet require counter weight changes to keep the pitch angle. There was a nice table that shows how many ounces to add/remove per thousand feet elevation change. I think this was the real downfall of the prop as counterweight changes are not a pilot doable thing....legally.
hotrod180 wrote:Bagarre wrote:...The manual tells you that field elevation changes of a few thousand feet require counter weight changes to keep the pitch angle. There was a nice table that shows how many ounces to add/remove per thousand feet elevation change. I think this was the real downfall of the prop as counterweight changes are not a pilot doable thing....legally.
And even if it was legal, do you wanna have to be monkeying with the counterweights every time you land at a different-elevation strip?
