Ah man Bagarre,
For some reason that is way beyond my "tech" skills to figure out all your pics are blanked out, my "polished 170" withdrawal symptoms are hitting an all time high !!!!!!
Bagarre wrote:The crazy thing is, I'm following how Google says to link to images and it works sometimes.
Following the link allows you to view the image but even for me, sometimes I can view them via the website here and other times I get a broken link.
Either way, I'll circle back to it at some point.
Zzz wrote:Bagarre wrote:The crazy thing is, I'm following how Google says to link to images and it works sometimes.
Is there a privacy setting in your Google Photos? It could be you can view them because you're authenticated to Google as the owner, but we're not.
daedaluscan wrote:That is looking really good, I am very impressed.
I really like the laminated wool/vinyl on the insulation. I have hesitated to strip my headliner out because I dont like the look of the raw foam. Definitely on the list now.
hotrod180 wrote:
Everything looks great!
I'm curious about the rear seat mod--
is this a field approval deal, logbook entry, or a Nike job (aka "just do it!")?
A friend of mine did something similar to his C180 bench rear seat years ago,
only he stretched ceconite on the seat bottom and back, kinda like on the BAS / Lakevue jumpseats.
Bagarre wrote:daedaluscan wrote:That is looking really good, I am very impressed.
If you do it, laminate a large section of foam (4'x4') and cut the panels out second with a sharp razor.
Trying to wrap the edge didn't look good to me.
It's a LOT easier to cut the foam and felt at the same time and the edge is a lot cleaner too.
The felt is 1/16" thick and holds shape against the edge of the foam nicely. I would have used headliner wool but no one makes it in dark gray.
The vinyl on the other hand looked terrible with a cut edge so I wrapped that.
